1 - 11 of 11 Posts
Right now I have Comcast and I'm not super happy with the service or the price. I'm thinking about going satellite. From what I hear Satellite generally has high picture quality. So are there any real drawbacks? Also which service is better? Right now I'm leaning towards Dishnetwork since it seems to work better with the R5000.
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
In most all cases, Comcast HD is better than either Dish or DirecTV. You can record with the HD DVR and archive using Firewire to PC or D-VHS.
Most often satellite transmits hd-light (1280x1080i vs 1920x1080i) Other than this reduced HD resolution (from satellite), I see no reason why pq should be any different.
I've got both cable HD (TWC) and Dish (former Bronze package). I find myself watching Dish much more often due to the greater number of stations. I've compared HD shows on common channels (TNT for example) and I can't say I see any real diff. I'm running a Z5 so I'm limited to 720p so that may be why I'm seeing much diff.
HTH
I have Dishnetwork and here in NY and it is much better than cablevision hd.
Not relevant.
HTH
Not relevant.
The OP is asking about Comcast and DBS, not CV or TWC. Please keep on topic.
Try OTA first, then compare.
Discussion Starter · #11 ·
Unfortunetly most of the channels are encrypted so firewire isn't really an option. Unless there's a way around that.
1 - 11 of 11 Posts
