Status
Not open for further replies.
1 - 2 of 2 Posts
Building a house and will wire it to have among other things 2 RJ-45 connectors to each room this cables will be home run to a central hub, my questions is would a use patch cables for this? or what type cable do i need to use?
If I understand your question correctly, you will use a cable you will see referred to contantly on this forum called category 5 cable. It is relatively inexpensive
1 - 2 of 2 Posts
Status
