Status
Not open for further replies.
1 - 2 of 2 Posts
will run approx 20' from cable box to x1...should i put the component to vesa adapter at the cable box (run vga cable) or at the projector (run component cable)?
thanks...
You are better off running the longer length of component cable from an attenuation standpoint. Inside the VGA cable are 5 micro coaxials which attenuate the signal more than RG-6 or RG-59 that you would use for component. So go with the long component run and a short VGA cable.
1 - 2 of 2 Posts
Status
