Hello,
I recently purchased a used Lexicon CX series amp. My pre-amp has a 12v trigger output which uses a 3.5mm plug. The CX amp has a trigger input which is simply two small pins (one positive and one negative). I can find mono cable that has 3.5mm plugs at both ends, but I can find nothing that connects to the amp's input. Does anyone know what this amp's input type is called, or where I can find a 12V trigger cable that has a 3.5mm plug on one end, and this unique Lexicon connector on the other?
Thanks for your help.
Brian
Brian
