1 - 2 of 2 Posts
I have a plama tv with cablecard mounted above a fireplace. Verizon Fios recently changed their encryption. My television is unable to view encrypted channels at this point. What is my best option to view encrypted channels? I don't think that a set top box would fit between the plasma and the wall.
Thanks in advance.
Phil
Premium Member
Tivos use the FIOS cable cards and they tune encrypted channels just fine so i don't see why your oldTV shouldn't do the same.
Have you contacted FIOS Cable Card support to see what the problem is? Maybe they just need to re-authorize your card, or give you a newer type of card etc.
1 - 2 of 2 Posts
