1 - 7 of 7 Posts
What cables should I run from my audio components to tv. Also when running speaker wire inside walls is there a certain route I should avoid. I was told HDMI cables are unreliable and should run audio video cables instead. My distance is 8ft.
You will be fine with an HDMI cable. I have a 12' one running in my main HT. It connects my Denon 4308ci to my 52" Sony XBR Bravia. I bought it off of Amazon for around $20. Here is a bunch of them to look at. http://www.amazon.com/s/ref=nb_ss_gw...+cable&x=0&y=0
And don't worry about the low prices, as I have $100 HDMI cables and $2 HDMI cables. I cannot tell the difference between any of them, as the HDMI signal is just data, 0 and 1's.
If you need to do really long runs, use Cat5e cable and baluns from these guys, http://www.avovercat5.com/product.htm
Hope this helps.
Mike
In regrads to speaker cable, this is what I used for my whole house system. It is sheilded and has a very heavy and slippery jacket for easy pulling through walls and ceilings. http://www.htd.com/speaker-cables-ac...-Speaker-Cable
If you are just running in one room, I would just stick with some good old 12 or 14ga clear jacketed speaker cable off of the bulk rack at Home Depot or Lowes. They sell it by the foot and will work just fine. No need to spend tons of money for what is essentially copper wire.
You can also get the wall plates with the speaker connections there. And I would use the banana plugs for a clean look.
Mike
Depends what audio components and TV you have
HDMI will be fine. Avoid routes close to line voltage wire.
Frank
not true at all if you're only running 8 ft of cable.
If you're running cables in walls, generally they need to be approved for in-wall use. They're usually labeled as such by the vendor ...
1 - 7 of 7 Posts
