Greetings
Spyder 2 has never been a good choice for lcd displays. It is almost always off to the red end. Likely by 500 to 800K too.
Some of the tri stim probes are fooled by the UV light given off by the bulb. It throws things off.
An i1 pro would be better for this technology.
A chroma 5 might be workable ... but you should have some form of optical comparator to double check its results.
Regards
Regards
