Quick update, reset my BC profile to defaults, iris off, high lamp, left contrast at 50, brightness to 52, dialled in grayscale (peak of 148 nits), used Dominics method above to dial in luminance, then did my 50/50 sweep and calibration across the 6 colours using auto generated patterns casted via nvidia sheild. When done the picture looked terrible! Most colours blown. Spun up Ryans disk and put a 50/50 red pattern on the screen and it was seen that the colours calibrated using the generated patterns were miles off. Eg ryans 50/50 pattern was landing on the 75! HCFR was set to 2020/P3. Should HCFR (3.4.5.1) be sending the same patterns as Ryans eg when colour space is set to 2020/P3 eg 50 sat free measure and generated patterns is sending a 50/50 or actually is sending a 50/75? I'm thinking the later the way the colours are lining up.
Currently redoing the colours using Ryans disk. While I can dial in the hue and sat using the CIE digram, how will I dial in the 3rd dimension, brightness, as appears HCFR is off showing the delta luminance for that sat?
