1 - 2 of 2 Posts
Hey, I was wondering if there may be any differences in calibration between the HS420 Sony models and the HS510. I just bought a KV-34HS510 to replace my KV-27HS420. It needs some tweaking, esp. in the geometry of the screen. In looking for some insight into repairing the HS420 I have gained alot of info into the tune-up procedures and was hoping that the same would apply for the HS510 models. Both TV's have a DA4 chassis, so I thought that it would be the same, just wanted a second opinion, Thanks for any advice
Very little difference, if any, in the service menu. If memory serves, one of the major differences is a subwoofer in the HS510. The HS510 has DVI and the HS420 has HDMI? I believe they both can suffer from the vertical scrolling bar.
1 - 2 of 2 Posts
