1 - 2 of 2 Posts
what kind setting u guys have for LN-S4095D TV inbcluding PS3 HDMI..
just wondering what Best setting should i go with with PS3 gaming and watching blu-ray
STandard or custom or movie
contract
bright
sharp
color
powering saving
do i use DNI and game setting to on or off...
What should i put for PS3 video setting... rgb full limit?
sorry to bother don't mean to ... if u can help me than thx if not its ok.... its worth a try to ask
 http://www.avsforum.com/avs-vb/showthread.php?t=1055906
Greetings
The best settings are those you determine by using a test disc and following the instructions.
If you don't want to invest even that amount of time ... then pick the movie mode and be done with it.
We are here to help if you have questions after you try the disc path.
Copying settings from others is not calibration.
PS3 ... RGB to limited and superwhite to on.
regards
1 - 2 of 2 Posts
