Trinnov Alt16, Parasound Amps, Martin logan speakers, 120” screen, SVS subs and dedicated media room
Hi all,
I will be ordering a CIII in about 1 month, and I'm planning on one Xtreme dac for the front 3 + sub, and one superior for surround and center back. I may get a 2nd Xtreme for sides and surrounds and skip the back center.
Without taking into consideration the DAC itself, is the side/surround array better (I've heard Theta uses the same signal for both, but time aligns and does a few other things) OR
Is it better to go with a Center Surround Channel? My room isn't that big, so I can't go with sides/rears and center surround.
What configuration do you guys have, and what do you think of the surround speaker array you have?
My room is 12x 19 x 9 high, and my surrounds are above my head and on the side walls and centered in the null area (between my ears), where they should be (dipoles) and I have 2 back surround channels (dipoles) in the ceiling shooting down at the listening position. My couch is on the back wall, so having sides/rears would literally be a straight line (my current surrounds and back channels are on the same horizontal plane).
Just not sure what's going to give me the most surround envelopment. I don't want 4 speakers on the same horizontal array giving me the same surround material (as would presumably be the case with side/surrounds).
So I'm thinking having the center back channel, and splitting the XLR cable to 2 amp channels, may be the way to go.
Lastly, IS CIRCLE SURROUND meant to work with sides/surrounds or surrounds/center surround configuration?
Thanks all, I appreciate it!
__________________
__________________
