Status
Not open for further replies.
1 - 2 of 2 Posts
Bought a Cambridge 540D player recently...came a week or two ago and when it came, right out of the box, it wouldn't load CDs or DVDs. It made a grinding sound when trying to load. Called the dealer, said to unplug it and then let it warm up and then try it. Bingo. Worked fine. The guy said it was a cold day and it needed time to warm up. It wrked fine for a while, but has slowly deteriorated...it started stopping in the middle of DVDs, then not making it from the root menu to playing, and now it just wont load. Turning it off and on or reloading the disc used to work, but now it just doesn't do anything. Sometimes it loads, and then just hangs up and I get the player on graphic screen. Sometimes it makes a grinding sound like a blender. It's a little drafty in my apt and has been cold recently...could this be playing a part or is this unit just a lemon? Either way, I'm bitterly disappointed.
ben
Sounds like a lemon, there should never be a grinding noise. Id take it back to the dealer for a exchange or id call cambridge direct. One of the 2 should get the problem fixed for you
1 - 2 of 2 Posts
Status
