Could anybody help in this situation please, thank you
I'm the owner of Denon avr 1910 (HDMI able). The source of movies is Asus laptop (OS Vista) or PC (OS XP). I would prefer to use PC for source because of better performance, but
Laptop has HDMI (v1.3), so no difficulties to connect avr to laptop through HDMI. With the K-lite codec pack (AC3filter included) I am able to output DD from PC instead of PCM (DD indicator is ON on the avr). I am using WMP as player.
Concerning PCvideo card is HDMI supported with 2xDVI outputs. Using SPDIF cable I connected integrated sound card and video card. Using DVI - HDMI adaptor and HDMI cable I connected PC with avr. Everything works: video and sound are outputted from PC, but only as PCM, and I can't force PC to output DD I tried the same codecs as on laptop, tried the latest version of the same codecs, tried to install separately the newest AC3 filter, tried to play with WMP, MPC, VLC options but no results - avr indicates only PCM received. Definitely it's the problem of PC, not avr couse it works fine with the laptop.
Is it just to do with some options on codecs, players, OS or something more I'm not aware? As far as I know SPDIF could be able to output DD and DTS. Maybe I should try other codecs or other players?
I appreciate for you help or guidances, thanks again.
