Status
Not open for further replies.
1 - 3 of 3 Posts
Just wondering,
For a 6ch audio cable (for dvd-a and sacd player to receiver) can one just use 2 x component cables (as one component cables has 3 coax cables), as arent these all just 75 ohms coaxial cables?
Would they sound they same instead of buying a dedicated 6ch audio cable ? ,which are expensive in Aus.
thanks
They'll probably be overkill but will work fine. As for the sound, stay with the basic recommendations of copper/copper and stay away from any 'clad' materials. You should be fine.
1 - 3 of 3 Posts
Status
