would this material be ok to mount on a home made frame? is it "stretchy" at all? my only reference is pearlbrite which has a consistancy close to electrical tape!! (ok, not quite...)
would i be better to order the fabric or order a model b or c and cut it?
if frame mounting is ok, has anyone done it before and how did you make your frame? my last screen was a torus....so i'm up for the challenge.
or would i be best to just go for the roll up???
thanks!
thanks!
