Status
Not open for further replies.
1 - 6 of 6 Posts
If your main use is PC and Xbox only, then I don't see how either would be better than another. When used a TV however I think you might want to lean towards the Syntax.
Discussion Starter · #4 ·
thank you for replying. can you elaborate on the reason i shoul d lean towards the syntax.
I've had both.
Sound is WAY better on the Viewsonic. I was quite impressed with the Viewsonic's speakers.
But my Viewsonic had a lot of issues... locking up... bad pixels... etc. I returned it and got the Syntax. No issues so far with the Syntax.
PQ is about the same on both units.
Discussion Starter · #6 ·
Originally Posted by DjPiLL
I've had both.
DjPiLL, thank you so much on this info.
1 - 6 of 6 Posts
Status
