Just wondering if anyone can give me an idea of the potential benefits of having this projector calibrated. Specifically, I'm interested in the adjustments of secondary colors. With very minor adjustments in the user menu, the settings read almost perfect with DVE. The greyscale is fairly good as well, but a little tweaking seems to improve it as well. The problem is, even though it seems to be se up correctly, the secondary colors, especially Cyan, are off. Yellow and Magenta are only slightly off, but the Cyan is almost a bright baby blue. It seems to have almost no green in it at all. I can correct it somewhat with the Tint control, but it negatively affects the primaries. I have also played around with the Gains/Offsets, but then the greyscale gets screwed up. Are there other adjustments accessible to the professional calibrator, that I am not aware of, that would help this situation? Is this just a case of a poorly engineered projector? I know it isn't just mine, as I had one before that I exchanged for a dead pixel, and it seemed to have the same problem. I also have read several online reviews, and no one has mentioned this. Any advice or insight would be greatly appreciated.
Rob
Rob
