Status
Not open for further replies.
1 - 4 of 4 Posts
My living room setup is sorta weird. I have a 42" plasma, and my roommate has a 27inch SD WEGA, they are sitting next to each other. We don't care about watching 2 different channels, but I want to be able to play xbox while he is watching TV and vice versa.
So instead of opting for 2 receivers (1HD and 1SD), we were thinking about just using one 811 receiver and hooking the plasma up to the DVI output and the other TV up through the component or SVideo output.
The brochure says both HD and SD outputs are active simulatneously, so this should work right? I should get the same picture on both sets with no degredation?
1 - 4 of 4 Posts
Status
