Can I run High Level Audio on Low Level Cable?
915 Views 3 Replies 3 Participants Last post by  dimes007
I already ran low level audio from my equipment stack to my subwoofer location inwall.
Now I'd greatly prefer a passive subwoofer with outboard amp in my main stack.
The cable already in the wall is the Belden 1505F.
http://www.bluejeanscable.com/pages/.../1505Ftech.htm
I have the required two conductors needed to pass speaker level audio but am I crazy to pass big sub amp power (Velodyne) over that cable?
Note that moving the outboard sub amp near the location of the sub is not an option.
--dimes
1 - 4 of 4 Posts
Too much current for 21 gauge wire. If you didn't staple the wire down, you could use one coax cable as a pull wire to fish 12 AWG speaker wire through the wall.
I haven't ever tried it, but maybe, just maybe, you can use the shield as the conductor. But I wouldn't recommend it.
Well, the shield is a conductor, and is used as a conductor, so, if you have two runs of this coax, then use the sheilds....it'll be fine.
UPDATE: So I also have a component video cable that I don't need to use since I ran DVI as well. So...
If I have a component cable and a subwoofer cable = 4 coax.
Use 2 cables (that's two shields and two cores) for +
and 2 cables (that's two shields and two cores) for -
....is that enough copper to get the job done for speaker level?
What is the approximate gauge of a typical shield in a low level speaker cable?
See less See more
1 - 4 of 4 Posts
