I have one coax cable (and one cat6 cable, if this makes a difference) that runs from a utility closet to the outside. The utility closet also has coax/cat6 running to all the bedrooms, so I can multiplex signal to whichever bedroom I need. I now wonder if having just one coax going to the outside is sufficient since I want 1) a roof antenna and 2) comcast internet connection. With just one coax, my only option is to have the roof antenna coax and the comcast coax from the utility pole connect into one coax coming into the house. Will this work? Will the comcast signal and the roof antenna signal get "mixed up" as they go through one coax that comes into the house? My goal is to be able to have a hard-wired LAN connection to each bedroom and should there be TVs in bedrooms I want them to be able to tune the over the air channels from the roof antenna. I don't want to pay for comcast cable, in which case I know one coax to outside is enough. Sorry if this is an obvious question and thanks for all the help.
