Relays are generally used for things like, Shades, voltage inputs for sensing or anything that requires a contact closure. Most AV equipment doesnt use this type of control unless you have a dedicated amp, some have triggers so they can turn on with a preamp.
Serial, some devices support serial control, it is a better way to control devices because it can support feedback. For example with serial control you can get Volume level feedback from a receiver. This is harder to program and wire than IR is and if you dont know what you are doing this is not the way to go.
The WF2IR device has 3 IR outputs, you can get dual emitters so you can handle 6 devices. Also you can wire emitters in series to control up to 4 devices per output usually, for up to 12 devices.
As for how Global Cache works, I have no clue and honestly I dont want to learn. If you just want a good Remote Control system I'd stay with URC. They have all the codes you'll want and work very well. They also have RF which is a non-line of sight way of communication to your system.
Good Luck!
Good Luck!
