Can someone help me with HDTV questions on Panasonic PT-AE500U please?
491 Views 8 Replies 4 Participants Last post by  babka
What would I need if I wanted to start watching HDTV channels on this projector. I am new to the HDTV arena but have heard that I need a HDTV tuner and an HDTV antenna and I can access around 18 HDTV channels for free if I am in the L.A San Fernando Valley? Is this true?
And how do I need to connect this if I am using the DVI output for dvd watching? Thank you everyone!
Status
Not open for further replies.
1 - 9 of 9 Posts
You need a stand alone ATSC tuner such as the LG 4200A or the Samsung SIR-415 to tune in your stations.
You also need to check out antennaweb.org to detemine what type of antenna you'd need for your location. In general most HD stations are broadcast in UHF and a normal UHF antenna will work, there are cases where the stations are VHF though. There is no such thing as a HDTV antenna, that's just marketing hype...
As for hooking it up, what options does the projector have? You might need to run a set of component cables to it or get a DVI switcher to allow you to hook two DVI sources to it...
I have that projector and there are 3 HD inputs. DVI, component and VGA are all HD capable and you can use any one of the three. Since DVI is the best of the three, it is best to use the DVI connection and you could use a DVI switch if you want to use your DVD player and HD STB connected to DVI. I have an HD VCR connected to component, DVD player to DVI and STB connected to VGA and it works fine for me. The STB I am using, the RCA DTC-100 doesn't have DVI.
If you are only interested in OTA HD and not cable or satellite, there are several possible models. A good antenna on the roof is probably necessary although some can receive OTA HD with an indoor antenna such as the Zenith Silver Sensor. The LG LST-4200A is still my favorite OTA STB and there are less expensive models that work pretty well. The section right above this one on Local HDTV reception should have a lengthy thread on reception in your area that you should read. Also, the ability to record OTA HD and watch at your convenience might be worth consideration. I know that I could never go back to watching live TV after having the ability to watch at my convenience. If you do want only OTA and the ability to record and watch at your convenience, the LG LST-3410A is worth consideration.
Chris
See less See more
Thanks guys for such helpful information. It looks like I need a UHF antenna. What if I decide to subscribe to HD digital satellite/cable eventually, can I still buy the LG tuner and use it now just with an antenna for the free 18 or so channels, and then use it later when I subscribe to HDTV satellite or cable?
Also, which indoor antenna is best ? I want to keep it simple and not have to climb the roof and install an outdoor antenna. But will the picture really for these 18 channels be HD quality just by buying an LG tuner and an indoor antenna? Its hard to believe.
Is the picture substantially better using DVI for this or will component suffice for free hd channels?
And if so, whats an good and inexpensive DVI switcher? Would ebay be a good place to buy it?
thanks again!
See less See more
You won't be able to use the tuner to get any premium HD channels like ESPN, Discovery, etc, you'd need a STB from your cable company. Cable companies are required to send out your local channels unscrambled in QAM format so if the tuner you get has QAM you should be able to get them. Actually if you have cable now, hook it up to your tuner when you get it and follow the directions to scan for channels, see if your getting anything now, it would let you avoid the antenna as long as your cable company carries all the channels you want.
As for an indoor UHF antenna, the Silver Sensor available at Sears is a crowd favorite.
Your picture would probably look fine with component cables but it's a question of is buying another set of cables to reach the projector and routing them better then spending extra on a DVI switch. Staying all DVI helps futureproof your system when HDCP comes along someday, of course a DVI switcher might be cheaper then, hard to tell...
As for inexpensive switchers, someone else will have to comment on that, I haven't needed one yet so I couldn't tell you which brands are the best...
See less See more
FYI, your best choice of media connection is DVI 720p with edid set to 2. Panny 500 does 1:1 mapping with this setting only. Assuming your ota receiver does a fine job deinterace 1080i to 720p.......if you don't care much of 1:1 mapping, all works just fine. Only the critical eyes can tell the differences.
Is this tuner still a great choice? or is there something cheaper ? and where to buy?
and if I get cable or a dish 1 day, will I still be able to use this for HDTV recording?
also, can someone recommend the best antenna and small HDTV for me?
I live in Van Nuys (San Fernando Valley) California.
thank you!
See less See more
"Is this tuner still a great choice? or is there something cheaper ? and where to buy?"
It's one of only a small group of OTA DVR's available and it's going to be discontinued shortly, LG is getting out of the STB market. Another option would be building a HTPC with an HD tuner card, you'd still be limited to only recording OTA or QAM broadcasts.
"and if I get cable or a dish 1 day, will I still be able to use this for HDTV recording?"
It's a stand alone, it won't work with a cable or sat STB so no.
what do you mean "edid set to 2" ??
1 - 9 of 9 Posts
Status
