1 - 3 of 3 Posts
I'd like to hook up my XBOX to 2 or even 3 of my tv's all using, lets say Input 1. The XBOX would be centrally located, probably in my basement in a closet. Besides using a remote (which can be done via IR Repeaters) I'd also like to use the controllers themselves of course to play a game at any of the 3 tv's. The problem is that at least 1 tv will be too far away, if not possibly all of them when you consider having to connect through floor boards/walls/etc. Is there a way to "extend" the range of the XBOX to have it's controllers connect to it from 30 or more feet away? Anyone?
Thanks in advance...
1 - 3 of 3 Posts
