1 - 2 of 2 Posts
The operation manual for my Sharp LC-70LE734U, under Picture Settings, Advanced Picture Settings, says "Film Mode" will be in the menu, after black level. I do not see "film mode". Where did it go? Thanks.
Check what mode it's in - the fine print in the manual says:
• "Film Mode" does not function depending on input signal
type.
• "Standard" does not function when channel display shows
an input signal resolution of 480p, 720p, or 1080p.
• "Film Mode" is not available during PC format input.
• "Advanced(High)" and "Advanced(Low)" do not function
when you set AV MODE to “PC”.
1 - 2 of 2 Posts
