So I have a Pioneer VSX84txsi which specifies 7.1 channel at 140 watts per channel. I've recently modified my speaker setup to install in-ceiling speakers for the center and rear-channels. I'm running it as 5.1 with the sub-woofer. I ran the auto MCACC to balance the speakers and all speakers are working in this mode and reproduce the test signals. I saved the result as memory-1 and ensured the receiver is set to the same MCACC setting.
So when I switch to watching TV, CDs, Netflix, or sound streaming with RDIO, I only get the front and center speakers (RDIO and Netflix are through my Roku 3 which then goes to the receiver). My sub-woofer and the rear channel in-ceiling speakers produce no sound. Yet, I'm convinced they are properly connected as the test signals all responded appropriately.
I checked the settings on Netflix and most movies are listed as stereo but I thought the receiver would split the sound-up as specified in the MCACC setting. Even if not, the CDs and DVDs suffer the same result with no outputs to the rear. When conducting the speaker modification, I noted the sub was incorrectly connected to a center channel but it seemed to work. I connected it to the sub output on the receiver and it responds only to the MCACC test signals - the cutoff is set to 80hz but I've set the value at a variety of settings with no difference.
So I'm confused as to why the MCACC works but all audio outputs do not feed all channels. Maybe the receiver is not splitting the signal? I'm running out of ideas and looking for suggestions....
