1 - 4 of 4 Posts
Premium Member
I have external amps and I am connecting to the preouts on the AVR, but I can only get the left and right channels to work. How do I set up the AVR to get the full surround speakers to work. And I don't know if this helps , but when I try the auto EQ, it always comes up as EO1 error (No front speakers connected) even though the test sounds play through the speakers just fine.
I am baffled?
Premium Member
Discussion Starter · #2 ·
I have zone 2 showing on the front panel if that helps anyone?
Is it safe to assume you have configured per page 26 of the manual?
Also, I'm not particularly familiar with inner workings of that unit but it would seem logical, at least to me, if you're working on a main/zone 1 setup that you'd shut off any other zones just to be safe/sure.
I don't use a Yamaha but with my Denon zone 2 is two channel stereo for another room, if that gives an idea.
I don't believe multi-channel sound is possible to zone 2 with my receiver although I haven't tried it at all.
1 - 4 of 4 Posts
