I am trying to get audio from my TV (when using its built-in DTV tuner) to play through my AV Receiver. It seems like this should be pretty easy but so far I can't figure it out.
What I have is a Samsung LN52B750 and Denon AVR-2310CI connected via HDMI. I assumed the single HDMI cable would be all I needed but when watching TV and the Receiver's source set to TV I get no sound. The TV is set to "External Speakers" and the receiver is set to "Amp"
Next I decided to try adding a digital optical cable, but I still get no sound when TV source is selected. As a test I tried assigning the OPT1 input to another source, with that source selected and the TV on I get sound (so I know the TV is sending sound correctly and the cables work), but with OPT1 assigned to the TV source I get nothing. (this is a workaround, but undesirable because I want the TV button on the remote to be what you press to watch TV, not something else. And HDMI CEC sets the receiver source to TV automatically)
At this point I thought maybe the receive expected sound through the HDMI cable but the TV wasn't sending it, so I disconnected the the HDMI cable so that the only connection between the two was the optical cable, still nothing!
I am at a complete loss. The manual doesn't indicated any custom settings that need to be set and I have tried everything I can think of. If it wasn't for the fact that everything else works flawlessly I would start to suspect the receive was defective. Any guidance would be a big help!!
