Status
Not open for further replies.
1 - 15 of 15 Posts
I live in an apartment complex. Consequently I can't run wire through the ceiling, wall, etc.
I have to run the wire from the floor up to the wall mounted speakers.
How do you guys recommend (VERY cheaply) hiding this wire?
I was thinking of getting those self-adhesive flat tubes that are used to hide electirical wire... but I'd need to get 2 of them and that would be $30 - I'm hoping for much less.... thats as much as I paid for the wire itself.
tape and paint it to match the wall.
Discussion Starter · #3 ·
maybe I can try to find white tape somewhere.
Thanks for the idea... anyone else have any ideas?
I have a few of my own - but I figure collective brilliance can't hurt ;)
how about flat speaker wire?
parts express flat speaker wire
also, if you have an ikea near you, they have those plastic channels for hiding wire. they're white, about 4 ft long and have a peel and stick backing. i don't recall exactly how much i paid (was about a year ago), but i don't think it was more than $5.00 for a pack of two strips.
Paint the wire the color of the wall. It's the simplest, cheapest and the thin wire will usually blend in better than any type of conduit.
-Justin
You can cut a groove in the drywall slightly deeper and wider than your wire. After placing wire in the groove, cover with spackle or drywall tape and paint to match. I did this in my old house and the wire completely disappeared. :D
Peace,
Watch out with the tape - I did this in an older place and at the end of the year, during move-out, the tape took with it much of the paint under it. I had to spackle/repaint./etc.
Premium Member
I have some taperwire for sale in the HT accessories classifieds for cheap...this is meant for this application.
Ron
$5 at home depot for 5 feet. I use this at my house.
Search for wire covering. I can't post links or pictures until I have more than five posts. :(
If it is physically possible to do so, by far the easier thing to do will be to drill a hole at the speaker and bottom of the wall and fish the wire through. Run the wire the rest of the way to your amp along/behind the baseboards. Heck, they may even be able to advertise the apt later as "wired for surround sound" or something.
lol I was a bad tenant.... in my old apt, I "accidently" made a couple holes in the wall. A little spackle and a very quick once over with paint (just the holes.... wasnt worried about a perfect job, just pass inspection) Less then 30 minutes of work is well worth hiding wires.... I will say the walls werent in pristine condition when I moved in though which probably made my decision a little easier.
PS I never told you to do this..... its just a figment of your imagination.
ha, I almost forgot.... the dartboard I put up was much worse then wire holes..... people always found ways to miss that board/cabinet.... good ol murphy's law
1 - 15 of 15 Posts
Status
