Hello everyone, greetings from Canada.
I have found all types of threads that come close to my situation but never the same.
Here it is:
WDtv LiveHub, works great.
Seagate 2TB tower, works great.
Yes, I can view and play any file from the Seagate Tower through the WDtv LiveHub.
I can use the WDtv LiveHub to scan and get all of the XML and Metathumb information which shows up automatically as you are scanning through to see what you would like to watch.
If I am scanning through the folders on the Seagate Tower, using the WDtv LiveHub, I can not get the Metathumb and XML information data. I can not request the information be loaded using the options on the WDtv LiveHub.
I even got the Metathumb and XML information by putting a movie file onto the WDtv LiveHub in a folder there. It scanned the movie file, downloaded the Metathumb and XML info and then I took the movie file, the Metathumb and XML info and put it into the folders on the Seagate Tower folder. When I go to the folder on the Seagate to view the movie using the WDtv LiveHub, I can see the movie file listed, I can play the movie, it WILL NOT display the images for the movie or the XML information in the background.
9 months of working on this and trying it all. Re-setting, re-scanning, re-loading, removing over 2 thousand movies and loading them again, changing the sharing folders through the Seagate System, on and on and on.
No matter what I do, nothing changes. All works perfect otherwise. Is it the end of the world? Heck no, but it is a colossal pain in the &^%(($^#.
Seagate forums say the problem is with the WDtv. They in turn say the problem is with the Seagate Tower.
Anyone want to take a crack at this or should I just say, "uncle" and forget it?
Cheers!
MovieLoonie
Here it is:
Cheers!
MovieLoonie
