Canton help...
894 Views 3 Replies 4 Participants Last post by  m_vanmeter
Hi
I have a pair of Canton's that i bought in 1982. The model is Xi 720.
One of the woofers in broken.
What are the chances that i can find a replacement part for this?
Any help is appreciated.
1 - 4 of 4 Posts
Look for the model of the woofer, on the back of the driver... you may get lucky and its something common that you could do also search for.
Canton i think is bigger in Europe, contacting them is a good first step. Sometimes these companies will suprise you and ship one out for a reasonable fee....
Other than that, searching US and european sources on the Internet ( ebay, google, etc) is another avenue.
If all else fails ... some adventurous types just try to buy a "close match" to the driver, at a good price. It will not sound perfect, and it may not even sound good.
I would try calling a Canton dealer to find out if they have a number to a technical support helpline. Accessories4less.com is a Canton dealer. Give them a buzz and see if they can put you in touch with a US Canton Support Rep.
if you can't get a Canton replacement, get a copy of the Parts Express catalog and try to match up the speaker with a modern replacement. If you go that route, replace the speaker in both units so they will match.
1 - 4 of 4 Posts
