I'm planning on buying a Panasonic HDTV (PT-50LC13) and setting up an HTPC system connected to it running Myth. The tv has a DVI port through which I'd like to connect the PC for best picture quality. The chipset on the PC (SiS 315/301B) does not look like it can output at 1280 X 720 (the tv's native resolution). It can do close (1280 X 768, 1024 X 768, 1280 X 960, 1280 X 1024), but not 1280 X 720.
I've been unable to find any good documentation on what kind of input you can put into a DVI port, so I hope someone will be able to answer some basic questions that I've been unable to find answers to on my own:
Do HDTV DVI ports only accept the standard 480p/720p resolution feeds? Does it depend on the tv?
Can you damage the tv by sending improper resolution signals through its DVI port?
If the tv can handle other resolutions, which one is likely to give the best picture quality - 1280 X 768?
If the tv has to compress or stretch the signal to display it, will the DVI option still give the best PQ? Or would I get better PQ by going through the tv's VGA port, which the Panasonic site says can handle up to XGA resolution?
Just about all my HDTV knowledge is from fancy book lernin (i.e. surfing) over the last 3 weeks - I don't have much hands-on experience. I do have years of experience in the analog video realm though. It can be very difficult sometimes to find answers to what should be basic questions. I have read through all the faqs and other info I can find, but there's not a lot of hard DVI info that isn't on the cursory side or assumes you know a whole bunch more stuff and leaves out details.
