Status
Not open for further replies.
1 - 2 of 2 Posts
most peope on this site seem to carpet- i think it helps acoustics (though i canot say why) and it seems to look better.
i am facing he same problem- carpeting is not always cheap.
now i am deciding between having the stage and risers (that were built into an existing room with existing expensive carpeting) carpeted with same capret or go for a black cheaper carpet or try to do some sort of cheaper option myself (like legato carpet panels)
not an easy choice
1 - 2 of 2 Posts
Status
