1 - 1 of 1 Posts
Hey everyone,
Not sure if this is the right place for help with diagnosing issues on my projector but hoping someone could at least point me in the right direction.
I have a Casio XJ-H2600 that is not functioning properly.
These are the light codes
Power/Standby: Amber Flashing to Red Steady
Lamp: -
Temp: Red Steady
The Casio manual has this explanation for it:
The projector was turned off automatically due to some problem that was probably caused by external digital noise or some other reason. Confirm that the POWER/STANDBY indicator is lit red (without flashing). After checking the POWER/STANDBY indicator, disconnect the power cord from the projector and wait for all of the projector’s indicators to go out. Next, reconnect the power cord and turn projector power back on.
If the error occurs again when you turn power back on, contact your retailer or nearest authorized CASIO Service Center.
Which of course solves nothing.
I've tried a bunch of different reset button solutions but nothing has worked so far.
Opening the top of the projector i don't see any blown capacitors, though i haven't fully disassembled it yet to check every one of them.
Thanks in advance!
1 - 1 of 1 Posts
