1 - 2 of 2 Posts
I have this patch panel and have a 1" thick pine board nailed to the cement wall in the basement.
I want to somehow mount the patch panel to the pine board and have it swing out so that I can reach the rear side of the panel. Do you have any recommendations? Thank you.
I'd use a hinged patch panel bracket. Google for "Hinged Wall Mount Patch Panel Bracket" and you should find what you are looking for.
1 - 2 of 2 Posts
