My unfinished ceiling height in the basement is 94". However, there is a gas line running perpindicular to the joists the length of the room, the pipe is 2.0" under the ceiling joists and unfortunately in the middle of the room. There is also some other copper plumbing involved making the idea of moving it all univiting.
The plan is to construct a frame using 2x3 wood studs 16" on center to frame the ceiling because of the plumbing, then use bailey D-1007 RC and one layer of 5/8ths sheetrock.
Questions are:
1. should I use my 3" roxul insulation in the joists or in the new frame or in both?
2. I also have a rolls of old conveyor belt. It is quite dense and heavy (oops did I just describe myself...doh) rubber based. It is about 3/8ths thick, if I were to use it, which layer would it be most effective if at all.
Thoughts and ideas much appreciated!
Steven
Questions are:
Steven
