Originally Posted by kumala /forum/post/13004322
I would like mount my pj, but it in a finished room and no way to rewire electrical and video, what would be the best solution to this problem. I could run wire covers along to wall and to ceiling, but fine for the hdmi cord but issue with an electrical outlet.
you can grab some plastic wire covers with double sided tape from home depot or lowes.I always use a screw or two ( with stud finder) as the wires can get heavy depending on how many you run.
If you do not have power on ceiling you can simply use Zip cord ,( its the same thing you would use to rewire an ordinary house lamp) it looks like speaker wire ,Don't go crazy with the gauge (14 gauge would be fine ) its available in any length longs as you need ,and its also found in home depot or lowes ect ect). you can place it along side the component wires wit no problem.
Then take your PJ power cord cut and solder shrink wrap to zip cord on both ends.
Also if all the wires fail to fit in the mold you can always spray paint the wires to match ( look at photo with black DVI cable before painting white).
cut thin pieces of double sided tape along side the plastic cover and silicon ( white or clear ) the thick cable along side the plastic molding.
use some thin mechanics wire ( under the plastic molding ) until the silicon dries it wont go anyware afterwards.
cheers
Murph
