Well I finally got my mandarax ceiling mount for my X1. I attached the mounting plate to the ceiling and drilled an 1.5†hole in the ceiling to route my VGA, Svid, and composite cable about 27’ from the X1. The video cable path will be through the ceiling, through the attic/crawl space, and down the wall which will hold the screen. The whole backside of the wall opposite of the X1 (screen wall) is completely open and stripped down to the frame awaiting new sheetrock to go up (bathroom is being remodeled).
So I am now left with a dilemma. Where am I going to plug the X1 power cord into?
1. Buy an outdoor grade extension power cable and route it through the ceiling, through the insulated attic, down the screen side wall, out a hole, and plugged into a UPC/power outlet.
2. Find some sort of nice trim or cover so that I can run the power cord on the wall from the ceiling down the back side of the room and down to a power outlet.
3. Hire an electrician to go in my small cramped dirty attic/crawl space so he can install a power outlet on the ceiling.
4. Or My cheap option [if this is legal] is to just pre-run the power wire myself from the power outlet from the backside of the screen side wall, up through the attic, and sticking out through a hole in the ceiling near the projector. I would then let the electrician just do his thing and let him connect/install a new power outlet in the ceiling without him having to go through the small dirty attic
So the problem with option #1 is I do not know if this is exactly gonna be safe running an extension cord through the attic of the house and through a wall like that. The insulation is very old up there and the last thing I want is to burn my house down.
The problem with option #2 is that I will have an unsightly power cable running down the middle of my newly textured wall. I’m kinda of a cable neat freak.
The problem with option #3 is of course is the $. I’m not sure how much it will cost to get an electrician to go up in the small attic, run new power cable and install an extra power outlet through the ceiling.
I am leaning towards number 4 but if number 1 is legal and ok, I may just go down that path.
So for all you ceiling mounted folks, how have you ran power into your projector?
