1 - 4 of 4 Posts
The center channel speaker for my Energy RC-micro setup burned out (has no sound so I supposed it's burned out
). Can someone recommend a good budget center channel speaker for my setup? How about the Polk Audio 15c center channel speaker? The receiver is Onkyo HT-RC260.
TIA,
The correct thing to do if you know for sure the speaker is dead is buy the same center again. It is important to have your front 3 speakers of the same company and model line to they timbre match (sound the same as sound pans from one speaker to the next).
Also to be sure you blew the speaker plug that speaker into the Left or Right channel on the AVR. If the speaker still has no sound then probably a blown speaker. BUT if the speaker plays then take one of the speakers from the Left or Right and connect it to the center channel on the AVR. If it doesn't play then you have an amp channel burnt out and its a receiver problem not a speaker.
1 - 4 of 4 Posts
