I just bought a new center speaker B&W HTM61 and am debating if I should mount the speaker over my screen or put in on a stand under the screen. I have matched it with a pair of B&W 863s (floor standing) speakers.
Does it make that much of a difference in sound to get speaker further from the ground?
Option 1: Mount over screen and use some kind of mount to direct speaker toward listening position. This speaker has a rear vent, by mounting close to wall how will that affect sound? Will I have to screw into center channel?
Option 2: Place speaker on stand under screen and position on same level as L/R fronts. My goal would be to get it as high and on line with fronts as possible them direct center toward listening position. Does anyone make an affordable adjustable tall 24 inches center speaker stand that will do this?
