1 - 20 of 27 Posts
Hey guys, I've worked with car audio for years but am a home theater newbie! I'm looking for some solid center channel speaker recommendations - currently, I have a Yamaha YHT-399 HTIB (budget buy) and the included NS-AP2600BL center speaker sounds a bit loose and boxy.
My budget is ~$100 and I'm just looking to improve on this stock underperformer!
The best center is matching it with the left and right front speakers if possible. Space is usually the reason people have to use horizontal centers. Keeping your speakers vertical and matching all 3 across the front will give you the best sound, IMO.
Originally Posted by AlexanderDelarg  /t/1510219/center-speaker-recommendation/0_100#post_24171901
This is exactly right.  You want a sound that pans across the front to not change tonal quality as it pans across the front, and the way to achieve that is by using identical speakers across the front.  The next best is "voice matched" speakers across the front.
  • Like
Reactions: AlexanderDelarg
Discussion Starter · #4 ·
Ahhh I see.
My L/R speakers are almost near the top of the TV, slightly above ear level, while my center is below the TV, much below ear level.. I'm not sure how to achieve this. I could place the center in front of the TV, but it blocks the IR receiver on the front of the TV! Wish they made some sort of small stand that the TV could sit on whilst on top of the bigger stand...
Discussion Starter · #6 ·
Those are pretty awesome! But if I move it on top of the TV, it would be even higher than my L/R speakers..
I have that mount, it is great, i have a 20# speaker on it. and having you center a little higher is not a big deal.
Originally Posted by clanderson  /t/1510219/center-speaker-recommendation#post_24174346
centers can be higher or lower than the L/R. The center just needs to be tilted towards the listener.
Originally Posted by AlexanderDelarg  /t/1510219/center-speaker-recommendation#post_24174365
and that mount allows you to tilt the speaker, i have mine at full tilt, my wife was worried the speaker would slide off. the mount comes with an anti slip pad.
Discussion Starter · #11 ·
Originally Posted by zieglj01  /t/1510219/center-speaker-recommendation#post_24174455
Also. that is a small center you have - this is bigger
http://www.amazon.com/Yamaha-NS-C210BL-Bass-Reflex-Center-Speaker/dp/B002JCSG2Q/ref=sr_1_2?ie=UTF8&qid=1389120897&sr=8-2&keywords=yamaha+center
http://www.newegg.com/Product/Product.aspx?Item=9SIA3BY14P6855
Wow guys, thanks for all of the helpful replies and suggestions, your input helps so much!
Andnd Zieg, that's actually the speaker I had in mind to replace my current one with. It's the same manufacturer, but seems a little better quality.
My center seems way worse sounding than my matching L/R and surround speakers.
Originally Posted by clanderson  /t/1510219/center-speaker-recommendation/0_100#post_24173856
Ahhh I see.
It is best if they are at the same level (that is, typically, one would want the tweeters at the same level), but some variance is generally regarded as acceptable.  I personally use three identical bookshelf speakers for the front, at almost exactly the same height, with the TV above.  But one does what one can, and how much deviation from perfection one is willing to accept plays a big part in this.
Discussion Starter · #13 ·
So now we've come full circle! Hahaha. My speaker positioning isn't optimal, but it's definitely acceptable - so would that bigger Yamaha center make a difference in SQ?
Originally Posted by clanderson  /t/1510219/center-speaker-recommendation/0_100#post_24177059
A better quality center is, all else being equal, better.  If it is a poor match for the right and left speakers, then it might be better, overall, to have a worse center that matches the right and left, but otherwise, a better center is always better than a worse center.  Of course, there is also the issue of whether something is enough better to justify the price.  For that, I suggest you listen and decide for yourself.  It is you who will listen, and you who will pay, so it is your opinion that matters on this issue.
Discussion Starter · #18 ·
Originally Posted by zieglj01  /t/1510219/center-speaker-recommendation#post_24186826
The NS-C444 is better and you can build around it in the future.
http://www.accessories4less.com/make-a-store/item/YAMNS333/YAMAHA-NS-333-5-2-Way-150-Watts-Bookshelf-Speaker-Pr.-Black/1.html
Very good point! But speaking of the future, would it be better to get this HTD L2 for around the same price? I've heard great things about them!
Maybe getting the HTD L2 would be best, so I could upgrade my L/R speakers to L2 or L3s down the road... You folks have me thinking!
Originally Posted by clanderson  /t/1510219/center-speaker-recommendation#post_24186934
Maybe buy the Level Two speakers first - and run phantom center - they will have
a 10% off sale starting Jan 24. Then save up for the center channel.
Discussion Starter · #20 ·
I'm thinking the HTD L2 right now, but does anybody have any other suggestions? I want to build around this speaker, and if I get the L2 I'll be committing to an HTD system.
So! Any suggestions would be greatly appreciated!
1 - 20 of 27 Posts
