Hey, Currently, I have the following setup:
Panasonic SA-XR55 Receiver
2x Athena AS B2.2 Fronts
1x Athena AS C1.2 Center
2x Bose bookshelfs Surrounds
All connected using Monster THX or XP wire, I forget which, from Best Buy.
I am going to order some banana plugs from here: http://www.monoprice.com/products/pr...seq=1&format=2
Do you thinks these are worth it, or will they degrade sound quality?
Also, is this speaker wire better than the Monster stuff? http://www.monoprice.com/products/pr...seq=1&format=2
Again, with the speaker wire, as far as the surrounds go, I was thinking about trying to find some white, thin wire to blend in with the baseboards, instead of the thick, copper colored Monster stuff - anyone ever seen anything like this?
Lastly, about speaker channels A & B. Right now I have my AS B2.2's on A and nothing on B. Would it be worth it to setup a set of Athena AS B1.2's on channel B and sit them beside / on top of the B2.2's? Right now they are sitting in the box - I bought them without ever having seen them as surrounds - needless to say they are a tad larger than expected, and didn't fit in the stands anyway.
