Status
Not open for further replies.
1 - 3 of 3 Posts
Can anyone tell me what the quality is of the RCA connectors used on the Denon 3802 receiver, and whether there would be a noticeable difference in sound quality if I were to replace these with Canares?
Diver,
Most of the manufacturers these days use off the shelf RCAs that solder directly to internal circuit boards. They usually come in “banks†that each accommodates several connections. In order to change them out you would have to have an identical replacement part (or a duplicate of the same) and have the necessary soldering skills and tools. As far as I know Canare makes connectors designed for cable, not circuit board applications.
Wayne A. Pflughaupt
1 - 3 of 3 Posts
Status
