Originally posted by versed On my machine, I use a a user defined IP address and not DHCP. With this setup, every time the machine reboots (every 3 or 4 days I think?) I have to go back into the network settings, pretend like I am going to change something but change nothing, and tell it to save the settings. If I do not do this after every reboot, the machine is disconnected from the net and unreachable, even though all the settings appear correct. The upshot is if you leave the machine in this state long enough, the channel guide will eventually appear blank. So, if you are using a user-defined IP address, I'd suggest going through the above procedure then forcing a net connection as described by lizzie. |
Originally posted by diverjones I have no problems like what you are describing, and have been running this way for several months. |
