Reports indicate that Hughes built boxes map 11-1 in error as a 480i broadcast instead of the 1080i capable channel it should be. On the other hand, WBBM-DT should be on 2-1 and non Hughes built receivers map it as 3-1. Just for fun, I told one of my Hughes built Toshiba DST-3000s that it had no dish connection. I figured it would map 11-1 correctly for a change and it did. It also mapped WBBM-DT as 3-1. It's looking like the difference between set types is that Hughes gets its local channel info from the DirecTV zip code database and the non Hughes sets gets it OTA. The NY people had a problem mapping their Fox digital channel and reported a collaboration between DirecTV and the STB manufacturer solved the problem. Maybe we should be calling WBBM about 2-1 and DirecTV about 11-1.
