4061 - 4080 of 17991 Posts
The DVR+ has discrete Power ON and OFF codes as documented in Channel Master's Support pages for the DVR+ CM-7500GB16 at http://support.channelmaster.com/hc/en-us/articles/200657770-Does-the-DVR-Remote-have-Discrete-On-Off-code-
2 Key codes are reserved for discrete power ON and OFF.
0x37 = ON
0x38 = OFF
Thank you. I did see those in my search of the Channel Master web site. Now if I find all the other codes. It would have been so much nicer if CM had provided them or better yet, made the commands available via IP.
I've had the DVR+ for a few few days, and with very limited time to play with it, I'm a happy camper. Set-up was a breeze. Within a few hours, I had several recordings for the kids. I was using pause during a World Cup match. Just what I was looking for...
That said, the tuner seems not quite as robust as the TV's (Samsung). I plan to experiment further, but a couple channels are now fringe, that were somewhat more reliable before. I hope I'm wrong...
Any reason not to stand the DVR+ on its side? I think I read somewhere not to though, but just curious. It's currently sitting atop our PS3, and as most know, is convex, so not exactly stable up there. I asked the CM rep before i got the unit, and he said no problem to stand it on edge, like many USB drives and other devices. With such a slim profile, on edge would fit perfect here and I'm sure other applications, and also get more breathing room around the unit.
[snip]
[snip]
Hmmm... that could be a problem for us. We've got... anywhere from 1 to 4 stations that could be knocked-out by a sub-par tuner.
SWMBO has given me leave to go ahead and order one, if I think that's a good way to go. First have to find out if the Antenna Experiment (testing a Winegard FlatWave Amped) succeeds. No point having a DVR if you're not (reliably) receiving things ;)
(So far it appears to be doing better than the rooftop antenna. Go figure.)
Jim
I think I remember seeing a CM advertisement for the DVR+where it was standing on edge behind a flat screen TV.
Of course you would have to buy the inferred remote extender.
Interesting. I was not aware of such an advertisement.
If I find where I read that it should be sitting flat, horizontally, I'll post back. That said, I'm going to fab a simple stand for it to stand up...
The tuner's reception, for some, worked better than their TV's. I was hoping to experience the same, but so far that's not the case. If after some experimentation that doesn't change, I'll contact CM to get their input.
Do all DVR+ units have the same tuner?
The DVR+ has no fan (and no internal hard drive) and it only gets mildly warm, so the orientation shouldn't be an issue. It would be better not have it sitting on top of another device that is already warm. Just provide some space around it to allow for normal ventilation.
On the phone with CM now.
Jordan said that they only have one tuner that they have used in the DVR+. Apparently others have also experienced decreased reception quality with the DVR+. Full refund within 30 days, if I decide to go that route. My only FOX and CBS channels that I got before going direct to the TV are gone or not watchable. And this is after lopping-off about 6 feet of coax, so a shorter run.
Warranty would simply check the unit, that it's working to spec, and if so send it back. Was hoping they might swap it out, thinking that a different box's tuner might make a bit of a difference.
I was under the impression that Channel Master will be adding channels in addition to Vudu onto their guide menu. I assumed they will magically appear after a firmware/software upgrade. Anyone know what and when they will be rolling anything out? I have a Roku already so I'm not starved for choices in that venue but I was curious if they are still planning to expand service this way?
I suspect that this is a bug. The DVR+ uses Linux. In a number of Linux/Unix utility programs, the dollar sign indicates "end-of-line".
I think you nailed it. Looking back through my notes last night all the iterations of the passwords i tried seem to match up with the explanation that the dollar sign truncates the password. I'm emailing Channel Master to let them know just in case this one isnt on their radar. Much appreciated!
AJ
I'll believe it when I see it.
Greetings,
Like many I had hoped Aereo would get the OK and be available in my area soon. But that's not to be.
So, I am looking at a CM DVR+. I don't know a lot about these things. But, I have attached a flat antenna to my TV and it picks up many stations with startling clarity. It looks great! Far better than my friend's cable TV image. :)
I have a few questions about the DVR+:
Can it set a timer on it to record a program like I used to do with my old VCR - that is, Record channel 4 for 60 minutes on April 2??? I don't want to be dependent on some subscription service that might fold in a year or two.
Do I have to use a CM hard drive on it to store my recordings, or can I use an old USB drive I have?
Can I play a recording back through my Roku with the wifi accessory?
Thanks for hour help.
Greetings,
Manual Recordings: Yes, you can set manual recordings. It's not the most straightforward of methods, but you can. FYI, as others have noted in this thread, TV stations are required to broadcast PSIP information along with their signals. Thus, the DVR+ will always have at least some EPG data.
Hard Drive: You don't have to use CM's hard drives, since they are readily available Seagates. Some people on this thread have reported better success with Western Digital than with Seagate. I've been using the Seagate STBU1000100, from Amazon, with great success. If you have a drive sitting around, connect it to the DVR+ and try it, with the prior knowledge that you MAY have problems. FYI, a number of people have reported problems using 2TB Seagates. Nobody knows why. Here's a list of CM-recommended Seagates.
500 GB - STCD500102
1 TB - STBU1000100
1 TB - STBX1000101
3 TB - STCA3000101
3 TB - STBV3000100
I wouldn't recommend a 500GB drive. You'll fill it up faster than you think.
Roku: Unknown, since I don't have one.
Banned
Greetings,
Tuners on the DVR+ are questionable. Stability of reception will vary greatly from location to location and is highly dependent upon antenna and placement. Unfortunately, it's going to be "trial and error" in terms of reception quality.
Manual recording is an option.
You will need an external hard drive.
"CM" doesn't produce them and the Seagate drives that they recommend have had reliability issues (for me personally and others). Personally, I would recommend a WD "portable" drive (if you're looking for the least expensive option). The least expensive readily available WD drive would be a "My Passport Ultra" 1 GB, which sells for approx. $70.00.
If you're referring to the CM "wi-fi accessory", it's designed to establish a wireless connection to a router for the Rovi guide updates. That's it's only function.
Banned
Tuners on the DVR+ are known to be questionable and very sensitive to location, antenna type and placement.
Unfortunately, a number of users (including myself) have had issues with this and have been dissatisfied. CM has produced devices (such as the CM-7000 DTA converter box) that produced exceptional results with flaky reception conditions. Sadly, this is not necessarily the case with the DVR+.
Odd, because early reports were their tuners were very good.
I'm going to order one later today. Guess I'll find out.
Six feet of coax, either way, isn't going to make any difference, unless it's really, really, really bad coax and it's six feet vs. one ;).
Jim
Banned
Jim
I'm uncertain as to what "reports" you're referring to. Regardless, as a general rule, if you're in a good location (relative to the distance from the transmitters and overall atmospheric conditions), you'll do OK (with certain antennas). The issues develop when you're in a questionable location. However, there have also been reports from users (such as myself) in less questionable environments who've also had issues. The bottom line is that the tuners used in the DVR+ could have (and should have) been better! They tend to be flaky and unpredictable!
......take it for a "test drive".
I've had nothing but good luck with the tuners in my DVR+. They deliver a sharper picture than the tuner in my Sony TV. In fact, I don't remember anyone on this thread claiming that the tuners were the cause of their problems. To prove such a thing, one would have to swap out the tuners in one's DVR+, then test the unit with the new tuners.
If you go back about 3500 posts :), to when AVSF users first started receiving product, you'll find glowing reviews of the tuners.
When I saw there was another 3500 posts to get to here, I decided to skip to the end.
Unfortunately, I'm in a marginal location. It shouldn't be. Save a few close-by trees (which may be the problem--but that doesn't account for wintertime): I'm at an elevation that looks "down" on all the towers, which are in a 12° arc of one another, about 14-16 miles away. Nonetheless: Reception can be problematical--particularly if it's storming, the wind is blowing or planes are flying overhead (we have an airport about one mile to the north, as the crow flies).
With the Winegard FlatWave Amped antenna I'm testing, things are much better, it seems. But the new (eight years ago) Winegard HD7078P VHF/UHF antenna on the roof has never done well. (Belden RG-6, all the way, weather-proof compression connectors crimped with a DataShark. [I used to be a "radio guy."])
Unfortunately: Short of putting up a tower: I've no other outside antenna options. And I'm not certain that would help. The symptoms kind of suggest reflections are the problem (the grade continues rising by an additional 400' or so [?] behind the antenna), which might explain why the inside antenna is actually working better than the outside one.
That's unfortunate :(
That's what I'll have to do.
If the tuner works well on receipt, can I expect it will continue to do so?
Jim
Banned
"Sharper" picture isn't the issue. I have no complaints in this area.
Video and audio stability (relative to the quality of the reception) is the issue (and it has been discussed here numerous times).
Swapping tuners isn't a realistic possibility!
Comparing various units (such as other OTA DVR's or DTA converters) is the only option for making these type of comparisons.
Banned
Jim
Yes (as a general rule).
