12101 - 12120 of 18705 Posts
Originally Posted by Paul210 View Post
I've verified on three different DVR+ units that there is a problem with closed captions on playback of a recorded program with the latest software version. I rolled my units back to the previous version and the problem with the captions is gone. Channel Master verified that this is a problem and said their engineers are aware of it. Maybe it'll get fixed on the next software release, whenever that may be. By the way, a cold boot fixes the problem temporarily but it always returns the next day.
Did 134R fix it?
I don't know. I've got updates blocked at my router. I'm not doing them anymore until I read all the ramifications.
This is weird: A few minutes ago I got an email from Channel Master telling me Newsy is now on channel 203. Newsy's been there for weeks! :confused:
Edit: OK, I see what's going on now. It was a "multipart alternative" email, but the text and HTML versions of the email don't match! The text version is the Newsy announcement, which I think came from several weeks ago. The HTML version is offering a low-pass filter for your OTA antenna. It blocks frequencies over 700 MHz (the former channels 52-69 which aren't used for TV anymore, but are now used for other purposes).
I have a similar filter already. Clearing out those high frequencies helps keep my distribution amp from overloading, and it lets me inject my satellite receiver into the coax as analog channel 64, so I can watch it throughout the house.
I looked at the filter (in fact, the page is still open on another tab). I'm not sure it would help me with my signal issues with the DVR+.
My weak channels are actually the high VHF channels 7 (ABC) and 9 (IND) in Los Angeles which are 174 - 192 MHz range. I have a Weingard indoor LNA-100 amplifier right before the DVR+ and three antennas - a UHF ClearStream 4 with their VHF add-on antenna and their purpose built combiner pointing toward LA, and then a purpose built antenna pointing the opposite direction for an ABC station broadcasting on real channel 27 tuned to bring in signals in the 548 - 554 MHz range. I get a strong signal on that station but it's weird; the Rovi guide data comes through on the sub channel for that station but not the ABC feed for some reason. I only get PSIP on the main channel. So I'd like to get more reliable signals through the DVR+ for that LA ABC station with the Rovi guide data. TV Fool report is at http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id=51343dc13705e8
I do feel like I get slightly better reception and less drop out on 7 and 9 going directly into the TV, a Samsung. I don't think a filter at the 700MHz range will improve things for me by itself but perhaps the adjustable gain would allow me to bump up or down the gain to see if that helps (the LNA-100 is fixed at 20db). Would it make sense to try it?
Hey, I have not kept up on the Hard Drive limitations. Will I have any issues using a 3TB (Western Digital) USB Hard Drive on the DVR+ with the latest FW?
Also, is it possible to transfers recordings from one Hard Drive to Another?
I was going to ask if LTE interference was really an issue. I'd buy an adapter for $5 but I figured most of my problems were multipath.
should be OK, try and tell us here - mfgs changing models too often to follow each one
not yet, but pachinko did show interest to add such feature in his SW
I seem to be in between two problems and can't get a fix for both. I have an outdoor antenna and am able to pick up several local channels, but have a problem with a few. My problem is that when I add a booster to the line I get 100% strength, but the quality goes from 100 to 0 and then back again with picture good to bad. I can take the booster out, but then I get a week signal. The booster is a powered booster I got from radio shack nothing special. Can anyone direct me in the direction to go to get both a strong signal without the loss of quality? When I hook this setup directly to the tv I have no problem. It's just when I use the dvr+ that I have a problem. There may be an answer somewhere in these post, but I can't find with a search and too many to go through one by one. Thanks for any help.
wrong thread
well, 1st - you'll need move your post to more appropriate forum, AVSforum has dedicated regional forums, ask there; 2nd - post there your location, better get from tvfool site a diagram and a table by your precise location, 3rd - there it would best place to get best answers !
How far away are your broadcast towers? What model antenna are you using? .
I had multi-path problems with my Winegard bat-wing antenna, causing the quality to jump up and down as you describe. Replacing it with a standard Channel Master Yagi-style antenna solved the problem. I am only 17 miles from the towers, so I did not need an amplifier.
Read the reviews on that card.
There are 121 reviews: 88% positive (4 or 5 stars) and 12% negative. However the negative reviews say both the card and the positive reviews are fake.
I've downloaded the h2testw utility to test it with when I get it. Amazon has a good return policy, so if it's a fake card I'll return it.
How to copy all DVR+ files to another USB HDD
It might depend upon the exact model of the USB HDD as to if it works or not, but I’m using a Western Digital 3TB My Book, model WDBFJK0030HBK-04 without issues in version 134R. Prior to version 124R, the DVR+ would only use 2TB on that HDD, but in 124R that limitation magically went away after re-initialization. Version 124R must be used to format disks larger than 2TB to their full capacity, but with disk manufacturers moving from 4096 byte sector sizes to 512 byte sector sizes, disks larger than 2TB fail to format properly in 124R, and require 123R or 124R to achieve 2TB (with remaining space not usable).
It is currently not possible to merge recordings from one HDD with another. DVR+ Lister Beta 16.9.1 provides the ability to merge recordings from one HDD to another HDD (always check for a later version on the post 1). Aside from that, you can manually copy ALL recordings from one HDD to another HDD, provided there is nothing on the other HDD that you want to retain. Here’s how using a Windows computer (others similar):
1. Backup any files that come on the new destination USB HDD before connecting it to the DVR+.
2. Connect the new destination USB HDD to the DVR+ and allow it to initialize it (format it). DO NOT record anything that you want to keep, as the following process will delete everything.
3. Disconnect the new destination USB HDD from the DVR+ and attach it to a computer.
4. Windows computers require Ext2Fsd version 0.62 or later (I highly recommend version 0.64 even though versions up to 0.68 were released) to be installed on the computer, in order to assign drive letters to both partitions on DVR+ formatted USB HDDs. Version 0.62, or later, is required to be able to delete files on the USB HDD (again, I recommend version 0.64).
5. Using Windows Explorer (or any file manager), delete all files and folders on the new destination USB HDD in both partitions (both drive letters).
6. Connect the old source USB HDD to the computer, and get drive letters assigned to both of its partitions.
7. Copy everything from the old source HDD to the new destination HDD, on a partition by partition basis. The 1st partition (which is the small partition) contains the various data files. The 2nd partition contains the TS recordings. Each partition has one empty "lost+found" folder.
8. Connect the new destination USB HDD to the DVR+ and give it a test by listing the recordings, and playing a few.
It's $5 off, not $5! With the discount it's actually $20.
And you're right, LTE interference probably isn't an issue for most folks. The filter might help if you have weak stations that need a preamp, but you have overload issues (stations get worse) if you use one. Or if you're trying to add your own analog channels for in-home video distribution (like I am), a filter like this might clean up "snow" from the channels you're adding.
Sorry for posting in the wrong place, but I thought since my problem is with a Channel Master DVR+ this was the correct place. I will look elsewhere.
Could we please stop dragging the thread to wrong direction ?
He's really not dragging the thread in the wrong direction at all. "When I hook this setup directly to the tv I have no problem. It's just when I use the dvr+ that I have a problem" could be the title of a book, and is no less common than the red light bug.
That would be a good book. But the DVR+ would only be one chapter. CM has no monopoly on this issue. The whole industry fails to provide tools to figure out how to fix the problem.
Did anyone notice CM is now selling the DVR+ 16 Gig model for $199 on their site. No announced on FB or via email that it is a sale. Wonder if they are trying to get rid of a lot of stock really quickly? Maybe trying to compete with the new Tivo OTA deal or possibly worried about losing their guide in the future.
It's kind of funny hearing people over here worrying about CM losing their guide and people on the TiVo board speculating that TiVo paid $1B for their company to shut it down. It's like gravity and profit motive have left the planet.
The $199 price is not that uncommon and not the best price we've seen. I paid $175ea for mine with free shipping a couple Black Fridays ago. Last year, they were 2/$300. The $199 price is a reflection of market circumstances -- CM wants to sell DVRs now not in November and does not want to lose sales to TiVo along the way. $199 plus $50 for a disk compares favorably to the 'All In' 1t TiVo OTA at $399.99.
Thanks for pointing out the applicability of the DVR+ tuner issue in this case. In my defense, a simple question was asked, and a simple, appropriate answer was provided. It could have ended there without the animosity that appears because someone didn't like the problem being addressed in this particular forum.
I am not a fan of cross-posting or useless thread tangents, but sometimes a straight line is indeed the shortest distance between two points. I see no need for the Thread Police to get their knickers in a twist because somebody asked for a little help. We do have a thread moderator to keep things on track, and I trust that person's judgement.
... The $199 price is a reflection of market circumstances -- CM wants to sell DVRs now not in November and does not want to lose sales to TiVo along the way. $199 plus $50 for a disk compares favorably to the 'All In' 1t TiVo OTA at $399.99.
Nope, it was just a mistake! The price is back to $249, and the following is from the CM face book page:
Channel Master: It appears that a technical glitch caused some users to see a $199 price for the 16GB DVR+ over the last day or two. This was a system price that had been set for a previous promotion. We apologize for the confusion, and for anyone who picked up a 16GB DVR+ at that price - it will be honored.
