It is Channel Master CM-9521.
The full package seems to be out of stock everywhere, however the CM web site says "temporarily unavailable" and has a link to be emailed when it is back in stock. You might find just the rotor unit on eBay or Craig's List.It is Channel Master CM-9521.
Not a heavy duty rotator, plastic gears inside. Having said that, it is available. Channel master ? Not so much.
I thought you were turning a consumer antenna. Twist your antenna with one of these RotatorsNot a heavy duty rotator, plastic gears inside. Having said that, it is available. Channel master ? Not so much.
Back when there was something in the Syracuse area worth tuning into I had a 16 element FM beam with a 7ft Channel master parabolic uhf antenna with a good rotor with all stainless steel gears. Sadly all the antennas are stored away with the rotor in the attic.I thought you were turning a consumer antenna. Twist your antenna with one of these Rotators
Me Want! Those are very nice! I only wish you could use a remote control with them.I thought you were turning a consumer antenna. Twist your antenna with one of these Rotators
