Check antennaweb.org - there might be an OTA (over the air) free HD signals in your area.
Originally Posted by Bill1313 /forum/post/12920255
As far as Cable Card Slots go your Panny models don't have them & from what I've read there have been a lot of problems with them probably why Panny droped them on the 2007 models.
Originally Posted by flood222 /forum/post/12920719
I have comcast basic TV but I also have internet ($63.11/mo total). I get 2,4,6,7,9 and fox HD channels as well as a host of other unscrambled digital content with my 700U. I think that when you have the internet package it opens up the ability to receive the QAM HD channels, but Im not 100% sure about that. You may be able to get it with just the analog package but I doubt it.
I am in Greeley - close to Denver.
As suggested above there is a comcast Devner thread in teh HDTV area of the forum. They'll have all the info you need.
Originally Posted by cosmos5861 /forum/post/12928770
I have a panasonice 50THpf9uk. We have basic cable with Cable internet. If this is true that I can get HD local with basic cable, how can I get it to work with my plasma. No HD receiver??
Originally Posted by tonestert /forum/post/12929285
I have a Pan TH-42PX60U and with the QAM tuner using Comcast I can only pick up a couple of HD channels. Over at the Harrisonburg / Charlottesville, VA - HDTV forum some others have also had trouble picking up HD channels with their Panasonic QAM tuners too.
I was hoping to get rid of my HD cable box but it looks like I will have to keep it to get all the HD channels.
Originally Posted by cdcrowell /forum/post/12935653
i have basic cable with no box.i get about 7 hd channels.my question is if i buy a box (hd dvr) on ebay will it have to be activated or can i just plug my cable up to it to receive more channels and be able to use the dvr function.i dont want to pay extra for digital if this can be done thanks
Originally Posted by joemama127 /forum/post/12935879
It depends on what kind you get...if you get a HD Tivo it will have to be activated and there is a monthly fee. Do you have a specific model you are looking at?
Originally Posted by optivity /forum/post/12920758
It's not an inherent problem with CableCARDs, but rather the Cable MSOs will do whatever they can, including providing very poor support, to dissuade the subscriber from using this less expensive device versus the revenue generated from a STB.
BTW, you will achieve a better quality picture with your PDP from using a direct digital input source versus a component/HDMI connection from a STB.
