Status
Not open for further replies.
1 - 2 of 2 Posts
Just got my Blockbuster DirecTV oval dish installed on Saturday (thanks AVSforum) so now I get my HBO via DirecTV. I need to call ATT Cable and reduce my services eliminate the premium movies, but keep enough service to retain CBS HDTV which I get on 117.1 and some expanded basic channels for the other TV's in the house (A&E, etc.) Do I need the Digital Bronze pkg @$40/mo or is there a way to get by with less ?
Also my signal strengths on the sat are ~85 on 101 and ~60-65 on the 119 -- should I expect to get better than that ?
Mike
Premium Member
Get the bare minimum package from AT&T. I belive they call it the "lifeline" package and it runs around $10 a month. You can expect to get up to 90+ and 85+ respectively with your oval dish. Do some fine tuning.
Kipp
IS THAT A REMOTE CONTROL IN YOUR POCKET OR ARE YOU JUST HAPPY TO SEE HDTV?
1 - 2 of 2 Posts
Status
