Status
Not open for further replies.
1 - 1 of 1 Posts
I found Channel 2 digital using the following setup on my DST-3000.
1)Plugged cable into input one, and set the input to Antenna.
2)Did a Scan. As expected really only picked up local VHF chnnels 2-12. But to my surprise 2-1 was setting there marked as Digital. Looks like it's channel 35, only has about 44% signal.
My DST-3000 must be acting funny or needs a code update. I have to set the Screen Ratio to 4:3 and the Image Shape to Cropped for the picture to be full screen. What's funny is I have to have the Screen Ratio on 4:3 for the Image Shape to display comment information about 16:9 images. If the Screen Ration is set to 16:9 then the comments that show up when you cycle through the Image Shape all talk about a 4:3 image .... Go Figure.
Anyone know how to get a code update on a DST-3000 that is OFA used only?
1 - 1 of 1 Posts
Status
